EXPORT POST PROCESSING DATA
Hi, I´m using COMSOL 4.1 to solve a model.
With COMSOL 3.5a, in order to export the post-processing data, there is a specific feature : export post processing data.
When can I find an equivalent in COMSOL 4.1? I just need to elaborate some results in Matlab!
Giulio
2 Replies Last Post 2011年4月27日 GMT+2 21:30
Posted: 1 decade ago 2011年4月27日 GMT+2 21:26
you have the Livelink (r) to matlab (r) and the explanations there (hardly used it in V4), then if its a simple text file, you can build a "table" and export that or a line graph and export the data
Hi you have the Livelink (r) to matlab (r) and the explanations there (hardly used it in V4), then if its a simple text file, you can build a "table" and export that or a line graph and export the data -- Good luck Ivar
Posted: 1 decade ago 2011年4月27日 GMT+2 21:30
in v4.1 you have the File Export model to Server (with Livelink you can then send it to Matlab) The new approach is somewhat different in V4, I'm still not used to it ;)
Hi in v4.1 you have the File Export model to Server (with Livelink you can then send it to Matlab) The new approach is somewhat different in V4, I'm still not used to it ;) -- Good luck Ivar
