Combination of different step() functions with prev() operator
Posted 2011年11月4日 GMT+1 15:10 Parameters, Variables, & Functions Version 4.2, Version 4.2a 0 Replies
I have an equation using prev() operator and step() function in order to generate a current that will be implented as a boundary condition:
i(t)=E/R(t)
i(t) is the value of current i at instant t(s)
E=constant voltage
R(t) is the value of resistance at tinstant t(s).
R is set from a triple rules over time:
1. If i(t-dt) * t < 2 then: R=1 (Ohm)
2. If i(t-dt) * t >=2 and if T(t)<300°C then: R=4 (Ohm)
3. If i(t-dt) * t >=2 and if T(t)>=300°C then: R=100 (Ohm)
T(t) is the temperature at isntant t(s)
i(t-dt) is the value of current at the previous instant t-dt (s). So: i(t-dt)=E/prev(R,1)
with the initial resistance at t=0s: R(t=0s)=1 (Ohm)
I would like combine these 3 rules to generate a current that depends on the current and the temperature.
By using step function, i have:
step_1(2): R jump from 1 Ohm to 4 Ohm at location: i(t-dt)*t=2 (appied for rule 1 & 2)
step_2(300): R jump from 4 Ohm to 100 Ohm at location: T = 300°C (applied for rule 2&3)
However, i don't know how to combine these two step function to represent 3 rule at the same time in COMSOL 4.2 ?
Dinh An
Hello Li-ion
