Drawing a repeated diamond pattern?
Hi all,
I am trying to make a model in which a repeated diamond pattern is cut out of an object. Basically a 3D rectangle with diamond shaped pores, the long axis of the diamonds being parallel to the length of the rectangle. I think this is done with an array? Does anyone know how to make this model?
Thank you for any help
TC
2 Replies Last Post 2016年9月23日 GMT+2 23:47
Posted: 1 decade ago 2012年1月24日 GMT+1 07:57
in the COMSOL geometry mode you have the "copy" command, instead of just typing in 1,1,1 for x,y,z, type in:
range(0,1,3) range(0,1,3) range(0,1,3) for x,y,z or
0 1 2 3 for each x,y,z
then you will get the original one at 0,0,0 and 3 copies at 1,1,1. 2,2,2 3,3,3
I hope I'm clear ;)
Hi in the COMSOL geometry mode you have the "copy" command, instead of just typing in 1,1,1 for x,y,z, type in: range(0,1,3) range(0,1,3) range(0,1,3) for x,y,z or 0 1 2 3 for each x,y,z then you will get the original one at 0,0,0 and 3 copies at 1,1,1. 2,2,2 3,3,3 I hope I'm clear ;) -- Good luck Ivar
Posted: 9 years ago 2016年9月23日 GMT+2 23:47
That makes sense. I have a similar question, but it brings up different challenges. How would you make "infinitely long" patterns? For example consider the following scenario. If I had two cylinders of different diameters (S-small and L-large) that are stacked end-to-end, how would I repeat the pattern in the z-direction? The scheme would look something like:
r-dir
| ... S-L-S-L-S-L-S-L-S-L-S-L ...
z-dir
Obviously, I could create many many duplicated features to achieve a similar result, but this is very inefficient. The goal is to avoid edge effects.
Thanks!
Caleb
That makes sense. I have a similar question, but it brings up different challenges. How would you make "infinitely long" patterns? For example consider the following scenario. If I had two cylinders of different diameters (S-small and L-large) that are stacked end-to-end, how would I repeat the pattern in the z-direction? The scheme would look something like: r-dir ^ | ... S-L-S-L-S-L-S-L-S-L-S-L ... - - - - - - -> z-dir Obviously, I could create many many duplicated features to achieve a similar result, but this is very inefficient. The goal is to avoid edge effects. Thanks! Caleb
