Show heat production in entire domain
I have simulated a vibrating field in a fluid, which is neighboring a solid. Now the pressure acoustics module provides the heat production in the fluid domain acpr.Q_pw and the solid mechanics module provides the heat production in the solid domain solid.Qh. Both heat productions can be shown separately. Is there a way to show the heat production for the entire domain?
1 Reply Last Post 2021年2月9日 GMT+1 23:09
Posted: 5 years ago 2021年2月9日 GMT+1 23:09
Hi Boris,
You can create a variable with the same name but different definitions in different domains. Use "Update Solution" to plot this newly-defined variable without having to recompute your model.
Hi Boris, You can create a variable with the same name but different definitions in different domains. Use "Update Solution" to plot this newly-defined variable without having to recompute your model. Best, Jeff
