volume force field for laminar flow simulation
I 'm doing a laminar flow simulation and want to introduce a volume force. I found an option for a constant volume force.
However, I want to introduce a position-dependent volume force. How can I achieve this?
Thanks.
PS: I'm using comsol 4.1
2 Replies Last Post 2012年5月3日 GMT+2 16:44
Posted: 1 decade ago 2012年5月3日 GMT+2 16:41
if you enter 100[N] in a field its constant for all x,y,z oer the selected range, if you write 100[N]*x/X_tot where X_tot[m] is a total X length you will have a linear increasing force going from 0 to 100 as x goes from 0 to X_tot (assuming it starts at x=0, else correct for the offset
Hi if you enter 100[N] in a field its constant for all x,y,z oer the selected range, if you write 100[N]*x/X_tot where X_tot[m] is a total X length you will have a linear increasing force going from 0 to 100 as x goes from 0 to X_tot (assuming it starts at x=0, else correct for the offset -- Good luck Ivar
Posted: 1 decade ago 2012年5月3日 GMT+2 16:44
Thanks. I'll try that.
Where can I find a list / documentation about variables / functions syntax?
Best Regards,
Lothar
Thanks. I'll try that. Where can I find a list / documentation about variables / functions syntax? Best Regards, Lothar
