Anisotropic electrical conductivity
I hope my question is quite simple for skilled people in Comsol.
I would like to perform modeling of a stack of conductive thin film. Thickness of the films are in the range of 100 nm, while the length of the system is about 1 m. Therefore, in order to avoid having a distorted mesh, I'd rather multiply the thickness of the film by a given z factor, and multiply the conductivity in that direction by the same factor... but not in the other direction.
Is there an easy way to define an anisotropic electrical conductivity?
Best regards
Fabien
4 Replies Last Post 2012年6月8日 GMT+2 06:56
Posted: 1 decade ago 2012年6月7日 GMT+2 08:08
first I would advise you to use a more recent version, then yes COSMOL allows for full tensor development of all related parameters, by default its in "isotropic" mode, check the node pull down menus
stacked thin film of nanometers on 1m long objct will be a challenge because of the dimansional ratio, and this for any FEM programme (limitations of the binary representation of number values) you should consider if there is not ways to use the thin film boundary conditions as probably you have no significant effects transverse to the thickness, or to use a coupled model 2D local in the film thickness and project that onto a 3D model
Hi first I would advise you to use a more recent version, then yes COSMOL allows for full tensor development of all related parameters, by default its in "isotropic" mode, check the node pull down menus stacked thin film of nanometers on 1m long objct will be a challenge because of the dimansional ratio, and this for any FEM programme (limitations of the binary representation of number values) you should consider if there is not ways to use the thin film boundary conditions as probably you have no significant effects transverse to the thickness, or to use a coupled model 2D local in the film thickness and project that onto a 3D model -- Good luck Ivar
Posted: 1 decade ago 2012年6月7日 GMT+2 17:41
Thank you for your reply.
I'll try to figure out with my company whether I can access a more recent version.
If so, how do I do to implement a tensor for the electrical conductivity :
[x 0 0] [0 y 0] [0 0 z] in the "electrical conductivity" value of the material?
Best regards
Fabien
Thank you for your reply. I'll try to figure out with my company whether I can access a more recent version. If so, how do I do to implement a tensor for the electrical conductivity : [x 0 0] [0 y 0] [0 0 z] in the "electrical conductivity" value of the material? Best regards Fabien
Posted: 1 decade ago 2012年6月8日 GMT+2 06:56
either you define it in the materials (check the material DB there should be some examples therein) or you define it in the main EC physics Electric conductivity User defined Anisotropic or whatever is relevant. You can also define a user coordinate system, it does not need to be the cartesian global x,y,z orientation
Hi either you define it in the materials (check the material DB there should be some examples therein) or you define it in the main EC physics Electric conductivity User defined Anisotropic or whatever is relevant. You can also define a user coordinate system, it does not need to be the cartesian global x,y,z orientation -- Good luck Ivar
This is so in my 45.2a I'm not sure everything was implemented in the early 4.0
Hi either you define it in the materials (check the material DB there should be some examples therein) or you define it in the main EC physics Electric conductivity User defined Anisotropic or whatever is relevant. You can also define a user coordinate system, it does not need to be the cartesian global x,y,z orientation This is so in my 45.2a I'm not sure everything was implemented in the early 4.0 -- Good luck Ivar
