In the Metal Phase Transformation, the phase transformation model customization is temperature-dependent
In the Metal Phase Transformation, the phase transformation model customization is time-dependent, how do I set it to be temperature-dependent. f_{A}=\frac{T-800}{900-100}
1 Reply Last Post 2022年3月21日 GMT+1 07:20
Mats Danielsson COMSOL Employee
Posted: 3 years ago 2022年3月21日 GMT+1 07:20
Hello.
The phase transformations are inherently time-dependent, but of course they also typically depend on temperature. If you define your own phase transformation, i.e. you define a rate expression, you can make this expression depend on temperature. In the physics interface, there are pre-defined variables for temperature and temperature rate, e.g temp.T and metp.Tt.
Mats
Hello. The phase transformations are inherently time-dependent, but of course they also typically depend on temperature. If you define your own phase transformation, i.e. you define a rate expression, you can make this expression depend on temperature. In the physics interface, there are pre-defined variables for temperature and temperature rate, e.g temp.T and metp.Tt. Mats
