how to define a variable in livelink with matlab which changes in a loop?
hi, I have a problem to define a loop in livelink. In the loop geometries with different shapes are created. The problem is how to define a parameter varies in loop? The .m file is attached below. Thanks!
2 Replies Last Post 2012年8月8日 GMT+2 16:27
Posted: 1 decade ago 2012年8月7日 GMT+2 20:19
on line 31, you have:
" i = 2:1"
This should be
"i = 1:2"
that will give i = [1 2]
I can't run your code from the console I'm at, but I'm pretty sure that's your problem.
on line 31, you have: " i = 2:1" This should be "i = 1:2" that will give i = [1 2] I can't run your code from the console I'm at, but I'm pretty sure that's your problem.
Posted: 1 decade ago 2012年8月8日 GMT+2 16:27
thanks!
thanks!
