Microwave oven waveguide configuration
Hi everybody,
I am trying to simulate a microwave oven using COMSOL, but I'm still a bit confused about configuring the waveguide. What is the difference between Transverse Electric (TE) and Transverse Magnetic (TM) mode? I know that when using Transverse Electric, the magnetic field is perpendicular to the direction of propagation, and the opposite happens when using the Transverse Magnetic mode. But what is practically happening inside the oven when using TE or TM mode? I mean how does TE or TM mode affecting the heated product?
Thank you so much in advance
2 Replies Last Post 2013年1月18日 GMT+1 21:51
Posted: 1 decade ago 2013年1月17日 GMT+1 22:12
Harvey,
TE and TM modes will result in different standing waves pattern in the oven, hence hot spots in the heated product will be in the different locations.
Most microwaves operated in a frequency range that ensure only the lowest TE10 mode can propagate. TM modes have higher cut-off frequency as compared to the dominant TE10 mode. Multiple mode propagation may cause dispersion, distortion and erratic operation. (There is Murphy’s law for waveguides: “If a mode can propagate, it will”)
Sergei
Harvey, TE and TM modes will result in different standing waves pattern in the oven, hence hot spots in the heated product will be in the different locations. Most microwaves operated in a frequency range that ensure only the lowest TE10 mode can propagate. TM modes have higher cut-off frequency as compared to the dominant TE10 mode. Multiple mode propagation may cause dispersion, distortion and erratic operation. (There is Murphy’s law for waveguides: “If a mode can propagate, it will”) Regards, Sergei
Posted: 1 decade ago 2013年1月18日 GMT+1 21:51
Oh I see! I understand now. Thank you sir!
