2013年3月13日 GMT+1 16:05
is your gravity also 2D-axi symmetric ? that is along "Z" the axis, if not you really need to go to 3D.
If its 3D axi, then be sure you have added a body force and an initial relative pressure difference that keeps your initial flow, at sea level 1m water hight adds quite some pressure drop ;)
2013年3月15日 GMT+1 10:21
Thanks for the reply.
The gravity is only working in the z-direction. I have attached a simplified test model I used to investigate the problem. It seems the volume force is working when heat is not implemented.
Simon
Simon
2013年3月20日 GMT+1 21:48
you have among other a confusion about the presure, and the sign of gravity I believe, betwen the body force and the pressure. In CFD you have the gauge pressure (set in the BC's) and the absolute pressure (set in the main CFD physics node) Normally athmospheric presure decreases with altitude, so you model is slightly confusing ;)
THen why use SPF and NITF or was it "just" t test the flow convergence ?
2013年3月21日 GMT+1 13:51
I'm made some changes, and put gauge (relative) pressure everywhere, that is the dependent variable p (p3 for the laminar flow physics). It should calculate the absolute pressure, which seems to be needed only for the density calculation at the material node. Changing the pressure in the material density function from pA (absolute pressure) to (p+p_ref) with p_ref being 1 [atm], or nitf.pA didn't make any difference either. The problem still doesn't converge no matter what configuration I use for the pressure.
The device I'm trying to model is placed upside down compared to the geometric model. This was corrected simply by changing the sign of the gravity force. I have tried both with positive and negative gravity, still with no solution.
I have been experimented with both using SPF together with hear transfer (ht), and to exchange them with the equivalent interface NITF, in hope that NITF has better integration between the physical effects. In the test file, the SPF was used to investigate if the solution converged if heat flow was neglected, which it did.
By the way, I made a support case with comsol about this problem, and are awaiting their response.
/Simon Tågerud
/Simon Tågerud
2013年3月21日 GMT+1 15:53
Hi again
I got help from the support, and it seems they pinpointed the problem. Appearantly the gravity force (source term) was to large, and thus the solution did not converge. This was solved by ramping up the volume force in the same way as when having a large reaction term in knowledge base entry 103.
www.comsol.com/support/knowledgebase/103/
Simon Tågerud
Hi again
http://www.comsol.com/support/knowledgebase/103/
Simon Tågerud
