Integration on a volume using a parameter
Posted 2015年1月22日 GMT+1 23:41 Microfluidics, Chemical Reaction Engineering, Results & Visualization Version 5.0 1 Reply
Dear COMSOL colleagues,
I am simulating the flow in a biological chamber, using laminar flow and transport of diluted species to simulate the convection and diffusion of oxygen in the chamber, as well as the consumption of oxygen by the cells inside it.
After running my simulation, I would like to have a distribution of oxygen.
What I can do is use a step function to calculate the volume inside the chamber above a certain threshold concentration (i.e. 70% of the chamber is below 0.3mol/m3, 60% is below 0.2mol/m3, 50% is below 0.1mol/m3).
But using the Volume Integration in Derived Values, I always need to specify this threshold (0.3 - 0.1 mol/m3).
That s why I would like to make a Volume Integration but for a range of thresholds (way more than what I could manually implement) to be able to plot Volume = function(threshold concentration).
Is there a way to make a 1D plot using some kind of integration function with a parameter that would vary ?
Thank you
Pierre
Thank you
Pierre
1 Reply Last Post 2015年2月3日 GMT+1 21:11
