Error in mphplot
Dear all,
I recently switched to COMSOL 5.1 on our Debian system, but when using it with MATLAB, I get a quite odd error.
Basically everything seems to work well, but when I try to plot some result using mphplot, I get the following error:
Error using strcmp
Too many input arguments.
Error in mphplot/l_getPT (line 485)
Error in mphplot/geomedgeplot (line 289)
Error in mphplot (line 223)
Other functions like mphgeom or mphmesh do not cause a problem. I also tried the same code on two different installations, one Windows and one Ubuntu and in both other cases it works.
So did anybody experience a similar problem and do you have some suggestions that I can try to fix it?
Thanks already in advance.
Hannes
4 Replies Last Post 2015年7月22日 GMT+2 20:36
Posted: 1 decade ago 2015年7月16日 GMT+2 22:03
I'm also having this problem. Did you find a solution?
Posted: 1 decade ago 2015年7月17日 GMT+2 14:47
Not yet, but we contacted the Support and I will post again as soon as we have a solution.
Posted: 1 decade ago 2015年7月22日 GMT+2 12:23
apparently it is a problem of the mphplot.p script in the COMSOL installation. The Support sent us an updated one for our installation to replace the old one. So if you contact them they should help you.
Hannes
Hi, apparently it is a problem of the mphplot.p script in the COMSOL installation. The Support sent us an updated one for our installation to replace the old one. So if you contact them they should help you. Best, Hannes
Posted: 1 decade ago 2015年7月22日 GMT+2 20:36
Thanks so much! I will reach out to them!
