Inconsistent units
I prescribed an oscillating inlet velocity boundary condition of the form u*sin(w*t) [say for example 20*sin(20*pi*t)] to a simple 3D cylindrical geometry.Once prescribed in this form, in the boundary settings dialog box only it is indicating 'inconsistent unit' and the unit 'm/s' will turn into a red colour.Can anyone help to find what exactly the problem is..
S.M.Ananth
5 Replies Last Post 2010年12月28日 GMT+1 21:33
Posted: 1 decade ago 2010年12月22日 GMT+1 14:17
In v4 red is an error in the formula (might be your use of u,v,w that are already used internally by COMSOL => variable name conflict). orange is a unit error. note that most functions sin, cos analyitcal ... requires dimensonless inputs ad are dimensonless at output, so
sin(20*pi*t)
is wrong as it should read
sin((20*pi)[1/s]*t)
or
sin(20*pi*t[1/s])
Hi In v4 red is an error in the formula (might be your use of u,v,w that are already used internally by COMSOL => variable name conflict). orange is a unit error. note that most functions sin, cos analyitcal ... requires dimensonless inputs ad are dimensonless at output, so sin(20*pi*t) is wrong as it should read sin((20*pi)[1/s]*t) or sin(20*pi*t[1/s]) -- Good luck Ivar
Posted: 1 decade ago 2010年12月22日 GMT+1 19:48
Dear sir,
Thanks a lot for the help.Eventhough it was a simpe mistake(but serious) I couldn't figure out.
S.M.Ananth
Dear sir, Thanks a lot for the help.Eventhough it was a simpe mistake(but serious) I couldn't figure out. S.M.Ananth
Posted: 1 decade ago 2010年12月22日 GMT+1 22:20
Hi Ivar,
I am using a function loaded from a .txt file. The name of the function is say fheat and in the .txt file it is given as:
%x y z fheat
0 0 0 1
0.1 0 0 1
..... etc.
Now, when I am using this function (fheat) in the COMSOL model, I get an 'inconsistent unit' warning. I am expecting that this function should be unitless because I haven't specified otherwise. Any thoughts?
Thanks much,
Deb
Hi Ivar, I am using a function loaded from a .txt file. The name of the function is say fheat and in the .txt file it is given as: %x y z fheat 0 0 0 1 0.1 0 0 1 ..... etc. Now, when I am using this function (fheat) in the COMSOL model, I get an 'inconsistent unit' warning. I am expecting that this function should be unitless because I haven't specified otherwise. Any thoughts? Thanks much, Deb
Posted: 1 decade ago 2010年12月22日 GMT+1 22:41
how do you call it up ?
if you use yourFunction(x,y,z) the three x,y,z have units, but COMSOL would expect none so here to you should use:
yourFunction(x[1/m],y[1/m],z [1/m])
or whatever fits. Anyhow units orange warnings are not errors and Comsol solves further anyhow, it is just telling us that here there might be something wrong
Hi how do you call it up ? if you use yourFunction(x,y,z) the three x,y,z have units, but COMSOL would expect none so here to you should use: yourFunction(x[1/m],y[1/m],z [1/m]) or whatever fits. Anyhow units orange warnings are not errors and Comsol solves further anyhow, it is just telling us that here there might be something wrong -- Good luck Ivar
Posted: 1 decade ago 2010年12月28日 GMT+1 21:33
Ivar, Just wanted to let you know that your advice worked perfectly. Thanks!
DD
Ivar, Just wanted to let you know that your advice worked perfectly. Thanks! DD
