Using geomcsg
I'm trying to specify boundary conditions from a Matlab .m file, and in order to be able to do this, I need to figure out the boundary numbers of corresponding objects I created in the .m file.\
Is it true that you can use the geomcsg command to find this information?
I read on another forum (www.comsol.com/community/forums/general/thread/8837) that the syntax that should be used is
ctx = geomcsg({object1, object2, ... objectN},'Out','ctx');
Should the arguments be the geometry object names (R1,R2,E1,E2, etc)? I tried using the object names, but I get an error when using the object names.
Thank you,
Kevin
P.S. If it's relevant, I'm using COMSOL version 3.5a
0 Replies Last Post 2011年1月25日 GMT+1 08:31
Hello Kevin Bachovchin
