initial parameter problem
I try to assembly three 2-D models in comsol. When I extruse one of the boundary value in a 2-D domain toward to another boundary of 2-D domain as boundary value. In the stationary slover condition, COMSOL does not work and give the following information:
Error:
Failed to find a solution for the initial parameter:
The relative error (0.00037) is greater than the relative tolerance.
Returned solution has not converged.
How can I do in the next ? thanks a lot !
1 Reply Last Post 2010年9月18日 GMT+2 02:12
Hello Guangji Ji
Posted: 2 decades ago 2010年9月18日 GMT+2 02:12
Same problem here with the AC/DC electric currents 3D app. mode. I am using the paradiso solver through matlab (comsol 3.5a). If I would be using comsol multiphysics directly, I would try changing the relative tolerance on the nonlinear settings within the stationary solver settings. What is the string necessary to change this property through scripting?
Same problem here with the AC/DC electric currents 3D app. mode. I am using the paradiso solver through matlab (comsol 3.5a). If I would be using comsol multiphysics directly, I would try changing the relative tolerance on the nonlinear settings within the stationary solver settings. What is the string necessary to change this property through scripting? Thanks
