High aspect ratio geometries: Internal Error in Geometry decomposition
Posted 2019年5月17日 GMT+2 15:06General, GeometryVersion 5.20 Replies
I need to create a geometry in which there are several small cylinders that intersecate other bigger (~50 times bigger in size) objects, usually blocks. For example, some operations involve the difference between a big block and a bunch of those small cylinders. If the size of the big block involved in the difference is too big, I get an error "Internal Error in Geometry decomposition", even when I press Build selected. If the block is not as big, I do not get the error immediately, but still I get it when I try to run Form Union. If the size of the block is smaller, I can run Form Union without problems. Moreover, the computation time used (both in the difference and in the Form Union) increases significantly as the size of the block increases. It seems that the problem is not a small angle or a small domain somewhere, but it seems to be the fact that I am subtracting two objects that are significantly different in size. I also noticed the the size of the virtual memory keeps increasing as try sequentially different sizes. This slows down also operations that were faster before.
Is there a way around? Thanks!
Hello Carlo Gilardi
