This is the log: After report this message, it will report error message. <---- Compile Equations: Stationary in Study 5/Solution 7 (sol7) ---------------
Started at Apr 22, 2020 11:53:52 AM.
Running on AMD64 Family 23 Model 113 Stepping 0, AuthenticAMD.
Using 1 socket with 12 cores in total on BRAVEHEART.
Available memory: 65.47 GB.
Number of vertex elements: 872
Number of edge elements: 8024
Number of boundary elements: 86909
Number of elements: 283592
Minimum element quality: 0.05497
Geometry shape order: Linear serendipity
Time: 16 s.
Physical memory: 21.77 GB
Virtual memory: 24.92 GB
Ended at Apr 22, 2020 11:54:09 AM.
----- Compile Equations: Stationary in Study 5/Solution 7 (sol7) -------------->
<---- Dependent Variables 1 in Study 5/Solution 7 (sol7) -----------------------
Started at Apr 22, 2020 11:54:09 AM.
Initial values of variables solved for: Solution 2 (sol2).
Solution time: 12 s.
Physical memory: 21.99 GB
Virtual memory: 23.77 GB
Ended at Apr 22, 2020 11:54:21 AM.
----- Dependent Variables 1 in Study 5/Solution 7 (sol7) ---------------------->
<---- Stationary Solver 1 in Study 5/Solution 7 (sol7) -------------------------
Started at Apr 22, 2020 11:54:21 AM.
Segregated solver
Number of degrees of freedom solved for: 4055345 (plus 592578 internal DOFs).
Segregated solver iteration 1.
Current distribution variables
Symmetric matrices found.
Scales for dependent variables:
Electrolyte potential (comp1.phil): 1.2e+02
Electric potential (comp1.phis): 0.86
Orthonormal null-space function used.
Iter SolEst Damping Stepsize #Res #Jac #Sol LinErr LinRes
1 0.0017 1.0000000 0.0017 2 1 1 1.2e-13 1.9e-16
Velocity u, Pressure p
Nonsymmetric matrix found.
Pressure (comp1.p): 1e+05
Velocity field (spatial frame) (comp1.u): 1.1e+03
Iter SolEst Damping Stepsize #Res #Jac #Sol LinIt LinErr LinRes
1 0.69 0.5000000 0.69 2 1 1 12 0.00047 1.6e-06
Heat transfer
Temperature (comp1.T): 1e+03
1 0.013 0.8000000 0.013 2 1 1 47 0.00094 0.00098
Mass fractions
Mass fraction (comp1.wCH4): 0.097
Mass fraction (comp1.wCO): 0.099
Mass fraction (comp1.wCO2): 0.088
Mass fraction (comp1.wH2): 0.027
1 1 0.5000000 1 2 1 1 4 0.0001 8.7e-06
Mass fractions (2)
Mass fraction (comp1.wO2): 1.2
1 0.00012 0.5000000 0.00012 2 1 1 100 0.25 1
2 0.0018 0.5000000 0.0018 3 2 2 200 0.31 1
3 0.00098 0.5000000 0.00098 4 3 3 300 0.46 1
4 0.00073 0.5000000 0.00073 5 4 4 400 0.77 1
5 0.0005 0.5000000 0.0005 6 5 5 500 1.3 1
Solution error estimates for segregated groups
0.0017, 0.35, 0.011, 0.5, 0.002
Residual error estimates for segregated groups
6.8e+04, 2e+03, 6.2e+03, 4.9e+04, 3e+03
Segregated solver iteration 2.
Electrolyte potential (comp1.phil): 0.16
Electric potential (comp1.phis): 0.38
1 0.1 1.0000000 0.1 4 2 2 1.3e-12 5.1e-14
Velocity field (spatial frame) (comp1.u): 0.34
1 0.57 0.5000000 0.57 4 2 2 21 0.00084 3.1e-06
Heat transfer
1 0.01 0.8000000 0.01 4 2 2 85 0.00097 0.00042
Mass fractions
1 0.42 0.5000000 0.42 4 2 2 8 0.00012 9.6e-06
Mass fractions (2)
1 3.3e-05 0.5000000 3.3e-05 8 6 6 600 0.18 1
2 0.00025 0.5000000 0.00025 9 7 7 700 0.3 1
3 0.00021 0.5000000 0.00021 10 8 8 800 0.55 1
4 0.00031 0.5000000 0.00031 11 9 9 900 0.98 1
5 0.00022 0.5000000 0.00022 12 10 10 1000 1.8 1
0.1, 0.29, 0.0082, 0.21, 0.0005 Residual error estimates for segregated groups
3.5e+03, 1.2e+03, 2.8e+03, 5e+04, 3e+03
Convergence criteria of the segregated solver are met but not all conditions for group Mass fractions (2) are fulfilled.
Segregated solver iteration 3.
1 0.084 1.0000000 0.084 6 3 3 1.3e-12 4.8e-14
1 0.75 0.5000000 0.75 6 3 3 31 0.00084 5.2e-06
Heat transfer
1 0.0096 0.8000000 0.0096 6 3 3 124 0.0008 0.00093
Mass fractions
1 0.29 0.5000000 0.29 6 3 3 12 0.00014 1e-05
Mass fractions (2)
