Comsol reports high virtual memory usage even when RAM is available
Posted 2010年10月7日 GMT+2 16:13 8 Replies
I have plenty of RAM on this machine (16GB) and I am running 64-bit Linux. Oddly, however, Comsol is indicating that it is using almost three times virtual memory as physical memory (screenshot attached). Shouldn't Comsol be using RAM first, rather than so much of virtual memory/swapping?
Could anyone explain to me what might be going on here? I am wondering if there isn't a way to force Comsol to use more of the RAM instead of virtual memory and hopefully get some speedup.
Thanks much,
Pranay
I noticed the same things but then I checked the swap use [ top in terminal or some "activity monitor" utility] and noticed COMSOL VM was NOT included in my swap memory that remained empty { I have a lot of Ram too. rarely need to use my swap files.]
Not sure what the Virtual memory means in COMSOL tough.
I notice the following in top:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
26546 pranay 15 0 3120m 1.1g 53m R 50.8 4.6 19:05.53 comsollauncher
There seems to be a VIRT in there. Although vmstat 5 consistently reports swpd=si=so=0 during the computation:
procs -----------memory---------- ---swap-- -----io---- --system-- -----cpu------
r b swpd free buff cache si so bi bo in cs us sy id wa st
1 0 0 14718308 66640 7246784 0 0 0 3 1 0 1 2 97 0 0
4 1 0 14716584 66640 7246796 0 0 0 8 1023 5626 15 1 85 0 0
I also found that cat /proc/pid/status reports the value indicated in Comsol's Virtual Memory pretty accurately in the field VmSize, which seems to be the total virtual memory allocated to the process (comsollauncher). Also: the VmPeak value was about the same value as VmSize, so from that it seems Comsol might actually be using that amount of virtual mem.
- Pranay
Just look the line above the process list.. [ I copy one output from my workstation below]
As you see the swap file is not used even if comsol says it use almost 5 gig of VM at the time I ran top. I was running a comsol calculation
I will trust the OS in that case. I am not a sofware expert and cannot really explain what these 5G of VM advertised by COMSOL are but it is a fact that they are not registered with the system. [ not even with the ram as my exemple below shows]
at least in my case....
it could be in the cached VM tough ... but this is beyond my expertise to figurethat out.
JF
Mem: 12389368k total, 4420064k used, 7969304k free, 356872k buffers
Swap: 32767996k total, 0k used, 32767996k free, 2728580k cached
4182 JFL 20 0 4994m 570m 44m S 226.1 4.7 3:41.44 comsollauncher
It's true that I do have to run a transient problem with a lot of time steps. But the issue of large Virtual Memory seems to be independent of the problem I need to solve: even if I simply start up Comsol - no model, no solver, nothing at all - the Physical memory reported is 288 MB and the VM reported is 2783MB. 10 times as much! (On my Windows laptop, which has a total of 4GB, both values are lower, just over half a GB in fact.) The command I'm using here is just:
[pranay@pgoel glnxa64]$ ./comsol -64 &
In fact, top seems to report a large swap space usage at startup as well:
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ SWAP COMMAND
11785 pranay 15 0 2746m 283m 28m S 1.7 1.2 0:14.23 2.4g comsollauncher
And I'm pretty sure that this VM is actually being _used_: it isn't just "reserved" but not utilized. For one, /proc shows this in VmPeak even without a model loaded. Further, when I do load my model in and try to run it, it throws a Java heap error unless I increase the heap with -Xmx -Xms:
./comsol -64 -np 2 -mpmode turnaround -Xmx8192m -Xms8192m &
(The -np 2 is gratuitous; I don't think two processors are being used, but these difficulties are independent of that anyway.)
I do eventually need to run a transient with a lot of steps, which of course is expect to take long. Now, I can't do much with the processor speed as I'm close to 3 GHz anyway, but I was hoping that I could thrown in a lot of RAM and hammer it out with a Direct solver. I didn't think the VM would trip me anyway. Hence the need to sort this business out.
Thanks for all your help,
Pranay
Did you ever find out why COMSOL is using more virtual memory than physical?
Sirisha
Are you using SATA II Hard Disk?
As per my knowledge, Virtual memory is the highest transfer rate from the hard disk. SATA II hard disks have 3 GBps.
I may me wrong also. But I am using a SATA III Hard disk in my workstation and the Virtual memory is 6 GB most of the times (6 - 6.2 GB).
Please correct me if I am wrong.
Thanks.
*nix style OS's have something called mmap() where files can be opened as if they are memory. If you open a file like this, it instantly becomes part of the "swap" with everything in it swapped to disk. This takes essentially zero resources till you start actually writing something to this file. From the get-go the program can access the file as if it's already in memory and the VM system swaps it in to physical RAM only as needed. This can be a very efficient way to do certain kinds of things and has little downside. I mean, alternatively you could open a file with read(), read it ALL into memory, and then let the VM system gradually swap it out to swap space as required. But that's a waste since you have essentially two copies of the file on disk.
So my guess is that COMSOL opens a bunch of files on the disk using the javaized equivalent of mmap() or something similar and actually only uses a small part of these files. It doesn't "cost" anything, but it does inflate the Virtual Memory number.
But again, this is just a guess.
Suggested Content
- KNOWLEDGE BASE What hardware do you recommend for COMSOL Multiphysics®?
- FORUM RAM usage
- KNOWLEDGE BASE Out of Memory
- KNOWLEDGE BASE Out of Memory During Assembly
- BLOG How Large of a Model Can You Solve with COMSOL®?
