Property not given- Property: yaxisexpr
Michael Rembe Certified Consultant
Is there anybody who knows this error:
"Property not given: yaxisexpr"
My model gets a stationary solution. After restarting the simulation to get a transient solution I get this error.
** Now I get the error by using the parametric solver AND restart, too!
Exception:
com.femlab.jni.FlNativeException: Property not given
Property not given
Stack trace:
at prop.cpp, row 589, ()
at com.femlab.solver.FlSolver.femTime(Native Method)
at com.femlab.solver.FemTime.run(Unknown Source)
at com.femlab.server.FlRunner.run(Unknown Source)
at com.femlab.util.i.run(Unknown Source)
at com.femlab.util.aa.run(Unknown Source)
4 Replies Last Post 2010年4月27日 GMT+2 11:10
Hello Michael Rembe
Posted: 2 decades ago 2009年12月18日 GMT+1 18:12
I have the same problem, Anybody know the solution.
Thnx!!
I have the same problem, Anybody know the solution. Thnx!!
Posted: 2 decades ago 2009年12月21日 GMT+1 16:23
I have never seen that fellow, cannot find the variable in the doc neither, so the best guess I can propose is to check whatever BC you have on the symmetry axis (y axis in axi-symmetry is the "z" axis easy to confuse), i.e. such as clear axial symmetry definition in all applicaton modes / physics
Sorry cannot do better, but pls report back, always interesting
Hi I have never seen that fellow, cannot find the variable in the doc neither, so the best guess I can propose is to check whatever BC you have on the symmetry axis (y axis in axi-symmetry is the "z" axis easy to confuse), i.e. such as clear axial symmetry definition in all applicaton modes / physics Sorry cannot do better, but pls report back, always interesting Good luck Ivar
Posted: 2 decades ago 2010年2月19日 GMT+1 17:57
I had the same problem and it appears that the .mph got corrupted.
I solved the problem by saving the model as a .m file (MATLAB).
The M-file can then be opened with the COMSOL gui and re-saved as a .mph
To use this functionality you must be running in the mode "COMSOL XX with MATLAB"
I had the same problem and it appears that the .mph got corrupted. I solved the problem by saving the model as a .m file (MATLAB). The M-file can then be opened with the COMSOL gui and re-saved as a .mph To use this functionality you must be running in the mode "COMSOL XX with MATLAB"
Posted: 2 decades ago 2010年4月27日 GMT+2 11:10
I had the same problem. First static solution, then frequency response.
The error was because I had defined a "probe plot parameter" that was not defined anymore. After deleting the probe the error was gone. Had nothing to do with yaxis or so (it was a global scalar variable).
Success!
I had the same problem. First static solution, then frequency response. The error was because I had defined a "probe plot parameter" that was not defined anymore. After deleting the probe the error was gone. Had nothing to do with yaxis or so (it was a global scalar variable). Success!
