Error when Solve Problem
When I was starting to solved problem of my project, I got this massage
Error: 9040
Fatal error.
- Type: OutOfMemoryError
Exception:
java.lang.OutOfMemoryError: Java heap space
(rethrown as com.femlab.util.FlFatalException)
Fatal error.
Stack trace:
at javax.media.j3d.GeometryArrayRetained.createGeometryArrayData(Unknown Source)
at javax.media.j3d.GeometryArray.<init>(Unknown Source)
at javax.media.j3d.TriangleArray.<init>(Unknown Source)
at com.femlab.view.aj.a(Unknown Source)
at com.femlab.view.aj.<init>(Unknown Source)
at com.femlab.view.PlotView3.k(Unknown Source)
at com.femlab.view.PlotView3.a(Unknown Source)
at com.femlab.view.PlotView3.<init>(Unknown Source)
at com.femlab.post.PlotCmdData.a(Unknown Source)
at com.femlab.commands.PlotCommand.evalOnClient(Unknown Source)
at com.femlab.commands.FlCommand.eval(Unknown Source)
at com.femlab.commands.a.a(Unknown Source)
at com.femlab.post.PlotType.a(Unknown Source)
at com.femlab.post.PostModelMph.a(Unknown Source)
at com.femlab.view.c.a(Unknown Source)
at com.femlab.gui.PostMode.a(Unknown Source)
at com.femlab.gui.GuiMode.j(Unknown Source)
at com.femlab.gui.au.a(Unknown Source)
at com.femlab.gui.au.b(Unknown Source)
at com.femlab.api.client.w.run(Unknown Source)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.dispatchEvent(Unknown Source)
at com.femlab.gui.e.dispatchEvent(Unknown Source)
at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source)
at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source)
at java.awt.Dialog$1.run(Unknown Source)
at java.awt.Dialog$3.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at java.awt.Dialog.show(Unknown Source)
i so need the solution for this problem to fix my minithesis
many thanks
best regard
Sari
1 Reply Last Post 2013年10月8日 GMT+2 06:18
Hello Hapsari Dewi
Posted: 1 decade ago 2013年10月8日 GMT+2 06:18
you may need to make your mesh size bigger.
or close some of the programs during running of Comsol.
If it is dynamic problem please increase time interval, it may work.
you may need to make your mesh size bigger. or close some of the programs during running of Comsol. If it is dynamic problem please increase time interval, it may work.
