coupling "mf" and "mfnc"?
please does anyone have an idea and if possible explain how i can create a model using physic - both "magnetic field"-mf and "magnetic field no current"-mfnc in different regions of the model?
the dependent variable for mfnc is Vm (magnetic scalar potential) and for mf are Ax, Ay and Az (vector potentials). what quantities in comsol do I use to connect both physics in my model?
merci
4 Replies Last Post 2017年8月4日 GMT+2 13:06
Hello Xife
Posted: 1 decade ago 2011年3月31日 GMT+2 09:08
Hey I am trying to do the same, but so far I haven't succeded, have you found any solution?
Posted: 1 decade ago 2011年4月1日 GMT+2 06:26
unfortunately, no.
I'm still hoping for an answer. i know some other FEM SW have this feature built-in. i think this would be an efficient computation method by reducing DOF created
what is/are your reason(s) for trying to do this?
merci
unfortunately, no. I'm still hoping for an answer. i know some other FEM SW have this feature built-in. i think this would be an efficient computation method by reducing DOF created what is/are your reason(s) for trying to do this? -- merci
Posted: 1 decade ago 2011年4月1日 GMT+2 09:32
I am studying the interaction between electromagnets and permanent magnets.
Well, I solved the issue using only "mf"
My first approach was to use both "mf" (for the electromagnet) and secondly "mfnc" for the permanent magnet.
I could'nt couple them correctly, so what I did is to select only "mf" and for the permanent magnet I set its properties using the Ampére's Law. I set the magnetization M in the the constitutive relation: B=u0H+u0M
The simulation ran well, at the moment I am checking if the results I got are correct.
Hope this helps, What are you working on?
Gracias a ti.
I am studying the interaction between electromagnets and permanent magnets. Well, I solved the issue using only "mf" My first approach was to use both "mf" (for the electromagnet) and secondly "mfnc" for the permanent magnet. I could'nt couple them correctly, so what I did is to select only "mf" and for the permanent magnet I set its properties using the Ampére's Law. I set the magnetization M in the the constitutive relation: B=u0H+u0M The simulation ran well, at the moment I am checking if the results I got are correct. Hope this helps, What are you working on? Gracias a ti.
Posted: 8 years ago 2017年8月4日 GMT+2 13:06
Dear Jose Perez,
I have the same problem "To check the effect of permanent magnetic field on gold nano sphere for the case of absorption spectra".
Please share your expertise with me.
Best
Ali
Dear Jose Perez, I have the same problem "To check the effect of permanent magnetic field on gold nano sphere for the case of absorption spectra". Please share your expertise with me. Best Ali
