Export data of Point Graph
Posted 2010年10月14日 GMT+2 22:03 7 Replies
In Comsol 4.0a, is it possible to export data from a 1D Point Graph towards txt file ? In the case where the x coordinate corresponds to a geometrical parameter (a radius of the geometry of my model), the exported file contains only the header and not the x,y data of the curve!
have youtried the excel format export ? (havnt 4.0a on ym PC here to test)
It seems that there is no excel format export in comsol4 (Is it true?), I only find the .txt file option.
Thank you for the answer. I tried "Spreadsheet" and "Sectionwise" data format and both didn't work. Furthermore, both data format correspond to a txt format. I don't see how to export toward a Excel format?
Thank you,
Guy
then its in Excel compatible txt format, try a convert data to table in Excel
Probably, I badly explained. The problem is that the txt exported file is empty and it only contains the header data such as.
But I found a solution !!!
I used a "Model Couplings" Definitions. Then, after computing, I plotted a 1D Global plot. In this case the Exported Data txt file contains all the data (header + x,y points).
Guy
Good approach.
One other thing, if you define a new coupling or operator, for postprocessing, you do not need to fully rerun your study, a: Study - SolverConfig - Solver - Solution - Update will do the job, and is mostly quicker
Guy
