2010年10月16日 GMT+2 17:19
this has been discussed a few times, try a search on the Forum, but I cannot remember the "good" solution, as I do not believe there is a "time integration" operator as for the space integration.
In som cases you can change the time variable to a space variable, if you can adapt the equations
Hi this has been discussed a few times, try a search on the Forum, but I cannot remember the "good" solution, as I do not believe there is a "time integration" operator as for the space integration. In som cases you can change the time variable to a space variable, if you can adapt the equations -- Good luck Ivar
2010年10月18日 GMT+2 18:56
see http://www.comsol.com/support/knowledgebase/913/
2010年10月18日 GMT+2 21:46
Thanks Ozgur, I forgot to search on the KB, I was sure it was somewhere ;)
Hi Thanks Ozgur, I forgot to search on the KB, I was sure it was somewhere ;) -- Good luck Ivar
2010年10月19日 GMT+2 20:29
[QUOTE] see http://www.comsol.com/support/knowledgebase/913/ [/QUOTE] Thanks, Ozgur
2011年10月19日 GMT+2 08:03
the suggestion was useful for me too!! thanks
2011年10月19日 GMT+2 10:56
see
Right on, Ozgur, and in release 4.2a we have some nice news on this topic:
New additional time-dependent solutions operators that you can use for results evaluation, for example:
- timeint() for time integration
- timeavg() for time averages
4.2a will start shipping end of this week.
Niklas
[QUOTE] see http://www.comsol.com/support/knowledgebase/913/ [/QUOTE] Right on, Ozgur, and in release 4.2a we have some nice news on this topic: New additional time-dependent solutions operators that you can use for results evaluation, for example: - timeint() for time integration - timeavg() for time averages 4.2a will start shipping end of this week. Niklas
2012年1月17日 GMT+1 15:58
Hello Niklas,
I was wondering where may I find the time integral function timeint()? It would be great if you may drop quick tips to use this function
However, sugestions from Ivar and knowledge base 913 was helpful.
-Thanks
Kumar
Hello Niklas, I was wondering where may I find the time integral function timeint()? It would be great if you may drop quick tips to use this function However, sugestions from Ivar and knowledge base 913 was helpful. -Thanks Kumar
2012年1月17日 GMT+1 16:37
The special operator "timeint()" is in v4.2a (1.66 is my current one) try a help search "timeint" or "special operators"
It's limited to post processing though. For the solver process you must go via the ODE as described in the KB
Hi The special operator "timeint()" is in v4.2a (1.66 is my current one) try a help search "timeint" or "special operators" It's limited to post processing though. For the solver process you must go via the ODE as described in the KB -- Good luck Ivar
