2010年10月16日 GMT+2 11:17
have you tried to add a global equation u3=int(u1,0,2) and then force it to 10 ?
Hi have you tried to add a global equation u3=int(u1,0,2) and then force it to 10 ? -- Good luck Ivar
2010年10月16日 GMT+2 13:01
Hi, Ivar
Thanks for your help!
The error of "Unknown function. - Name: Int" was obtained when I followed your advice. The error occured again when "Int" was instead by "Integral". It seems that there was no built-in "integral function" in "Global equation".
Then how to handle it?
thank you very much!
youf.
Hi, Ivar Thanks for your help! The error of "Unknown function. - Name: Int" was obtained when I followed your advice. The error occured again when "Int" was instead by "Integral". It seems that there was no built-in "integral function" in "Global equation". Then how to handle it? thank you very much! youf.
2010年10月16日 GMT+2 16:33
sorry for that int() is my shortcut for integration (Model coupling)
Hi sorry for that int() is my shortcut for integration (Model coupling) -- Good luck Ivar
2010年10月17日 GMT+2 12:43
another thing, when I see a PDE solution that is oscillating in line with the mesh, I know by experience that then the BC are overconstraine and your equation set is not correct, so I believe your example is not a coherent set of equations and BC's, there is something too much in there ;)
Hi another thing, when I see a PDE solution that is oscillating in line with the mesh, I know by experience that then the BC are overconstraine and your equation set is not correct, so I believe your example is not a coherent set of equations and BC's, there is something too much in there ;) -- Good luck Ivar
2010年10月18日 GMT+2 03:04
Hi, Ivar
Thanks for your help very much!
I has tried the "integration (Model coupling)" setting, but unfortunately the satisfying result can not be obtained. I think I must tried again and the process is required for a new user of Comsol.
Thank you for testing the example. It has not real significance. What I want to know is setting the integral equation. The boundary conditions is really too many for the equations.
youf.
Hi, Ivar Thanks for your help very much! I has tried the "integration (Model coupling)" setting, but unfortunately the satisfying result can not be obtained. I think I must tried again and the process is required for a new user of Comsol. Thank you for testing the example. It has not real significance. What I want to know is setting the integral equation. The boundary conditions is really too many for the equations. youf.
