Coil Group Box under Multi-Turn Coil
In axial-symmetric geometry I am simulating magnetic fields created from multiple multi-layer solenoids stacked on top of each other.
I am using the Multi-Turn Coil function, and had a question regarding the number of turns applied when checking the Coil Group Box.
Let's say I have the box checked, and I have 100 turns as my value for N. If I select 2 domains, will it simulate 100 coils in each domain or will it split the number in half?
Thank you!
1 Reply Last Post 2016年2月14日 GMT+1 20:23
Nirmal Paudel COMSOL Employee
Posted: 10 years ago 2016年2月14日 GMT+1 20:23
Hi William,
If you have used Multi-Turn Coil domain used for two domains (for example, Domain 4 & Domain 5) with N=200, I =1[A] and Coil Group option checked, then COMSOL will treat these two domains connected in series (as Coil Group option is ON) and setup 200 turns for each of the Domains 4 and 5. In total, Domain 4 and Domain 5 will have 400 turns. Hope this helps.
Best Regards,
Nirmal
Hi William, If you have used Multi-Turn Coil domain used for two domains (for example, Domain 4 & Domain 5) with N=200, I =1[A] and Coil Group option checked, then COMSOL will treat these two domains connected in series (as Coil Group option is ON) and setup 200 turns for each of the Domains 4 and 5. In total, Domain 4 and Domain 5 will have 400 turns. Hope this helps. Best Regards, Nirmal
