Geometry using loop
In my model the number of rectangles in geometry is user input dependent variable. So I need to use a loop to create the geometry. So I have written the following code,
N=input ('Enter the number')
for i3=1:N
g(i3+1)=rect2(100e-6,12e-6,'base','corner','pos',[0,depth]);
depth=depth+10e-6;
end
Is this format g(i3+1) is acceptable for COMSOL ? If no then how should I write it?
Please help.
6 Replies Last Post 2011年3月28日 GMT+2 10:45
Hello Ahmad Zubair
Posted: 1 decade ago 2011年1月27日 GMT+1 05:53
Have you got any answer for this problem? I am also looking the same
Posted: 1 decade ago 2011年1月27日 GMT+1 07:16
first of all you should specify the version you are using, that would stimulate the right people here on the Forum.
Then, why not try it out and see in the COMSOL GUI environment what you get ?
Hi first of all you should specify the version you are using, that would stimulate the right people here on the Forum. Then, why not try it out and see in the COMSOL GUI environment what you get ? -- Good luck Ivar
Posted: 1 decade ago 2011年1月27日 GMT+1 10:41
No, I'm still in the same problem
Posted: 1 decade ago 2011年1月27日 GMT+1 11:03
I need to built a model that can be used for structures with different number of subdomains based on the users demand. Is there any way to do it using GUI?
Posted: 1 decade ago 2011年3月25日 GMT+1 16:28
I stere a solution to this Problem availible?
Posted: 1 decade ago 2011年3月28日 GMT+2 10:45
Hello, I am new to this forum and I see a lot of topics open like this. Is there an active community or is this dead?
I also try to build a geometry using a loop:
for i=1:L
g{i}=rect2(0.8,width*i,'base','corner','pos',[0,width*(i-1)]);
s.objs={g1(i)};
s.name{i}='R' & num2str(i);
s.tags{i}= 'g' & num2str(i);
end
but it appears not to work out. Is there a solution for this? If one has a solution could he/she post the correct syntax (not like this www.comsol.com/community/forums/general/thread/6131/ )
Hello, I am new to this forum and I see a lot of topics open like this. Is there an active community or is this dead? I also try to build a geometry using a loop: for i=1:L g{i}=rect2(0.8,width*i,'base','corner','pos',[0,width*(i-1)]); s.objs={g1(i)}; s.name{i}='R' & num2str(i); s.tags{i}= 'g' & num2str(i); end but it appears not to work out. Is there a solution for this? If one has a solution could he/she post the correct syntax (not like this http://www.comsol.com/community/forums/general/thread/6131/ )
