Error while using Matlab LiveLink
I'm facing a problem while using Matlab LiveLink.
geom1 = model.geom.create('geom1', 2);
c1 = geom1.create('c1', 'Circle');
c1.label('c1')
c1.set('r', '40');
c2 = geom1.create('c2', 'Circle');
c2.label('c2');
c2.set('r', '20');
dif1 = geom1.create('dif1', 'Difference');
dif1.selection('input').set(c1.label);
dif1.selction('input2').set(c2.label);
The code above gave the following error.
No method 'set' with matching signature found for class 'com.comsol.clientapi.impl.LocalGeomObjectSelectionClient'.
Error in
Could anyone explain why this is happening?
2 Replies Last Post 2016年4月18日 GMT+2 10:01
Posted: 9 years ago 2016年4月18日 GMT+2 04:06
Hi, Harutaka:
If you input like this, it might work:
dif1.selection('input').set({'c1'});
dif1.selction('input2').set({'c2'});
I'm running into the same error while I'm trying to change the {index} into domain number, but it never work and I don't know why. If you know something about this, please tell me, thanks.
Hi, Harutaka: If you input like this, it might work: dif1.selection('input').set({'c1'}); dif1.selction('input2').set({'c2'}); I'm running into the same error while I'm trying to change the {index} into domain number, but it never work and I don't know why. If you know something about this, please tell me, thanks.
Posted: 9 years ago 2016年4月18日 GMT+2 10:01
Thank you for your reply, Yang.
I tried what you suggested and it worked.
I have no idea why "dif1.selection('input').set" doesn't take "c1.label" as an argument.
Thank you for your reply, Yang. I tried what you suggested and it worked. I have no idea why "dif1.selection('input').set" doesn't take "c1.label" as an argument.
