different frames in comsol 4.0
Hi, I have got a problem associated with frames. In my modelling, I have three general form and a moving mesh. two general equations are to be solved under spatial frame and the other one is to be solved under material frame. I have done this in comsol 3.5. But I couldn't find out how to do this in comsol 4.0. Can someone help? thanks a lot
1 Reply Last Post 2010年11月9日 GMT+1 07:47
Posted: 1 decade ago 2010年11月9日 GMT+1 07:47
I'm not sure it helps a lot, but in V4 you can define your operators on the different frames, the same for the solvers data sets (the postprocessing integrations are by default set to the solver defined frames, this somethimes fools you, be aware).
Another difference in V4 the structural uses the spatial frame by default as driven by the displacements. (this was off by default in 3.5. Often this alows to remove a moving mesh case and simplifies the mode set up
Hi I'm not sure it helps a lot, but in V4 you can define your operators on the different frames, the same for the solvers data sets (the postprocessing integrations are by default set to the solver defined frames, this somethimes fools you, be aware). Another difference in V4 the structural uses the spatial frame by default as driven by the displacements. (this was off by default in 3.5. Often this alows to remove a moving mesh case and simplifies the mode set up -- Good luck Ivar
