2010年11月11日 GMT+1 14:18
I suppose its related to the height/size ratios 5nm versus 1mm is 1:200'000, I never use ratios (for the mesher) largeer than 10'000 or if possible less.
The true question is what do you want to resolve within your 5nm layer? , cannot you replace its presence by a "thin layer" with a bulk equation form ?
Then have you calculated what it represents to have a 1nm (to have let's say 5 meshes across your 5 nm thick layer) sized mesh elements to fill several mm^3, probably you need a nice cluster just to fill one matrix, not to talk about solving
Finite elements are limited by the "finite" size of RAM on ourPC/WS's ;)
2010年11月12日 GMT+1 18:12
That's a good point. Thanks very much.
Michael
Michael
2010年11月17日 GMT+1 21:03
I have been able to create a composite object by making the box that encapsulates everything smaller. However, I have now had a lot of trouble meshing and getting a solution. I cannot mesh the entire object using Free Mesh even with an extremely coarse setting without running out of memory. If I try to Sweep Mesh the small sections of the model and Free Mesh the rest I often get a 'Singular Matrix' error (which I do not understand). I have been able to mesh the entire object under a few circumstances, but when I then try to solve it I get a 'Empty cavity generated' error.
I assume that this is because the resolution of the mesh is not small enough in the very thin regions. I can perhaps try approximating the thin layer with a 2D sheet but obviously it would be ideal if I could simulate exactly what is happening in the electrodes.
Thanks for any suggestions you might have.
Michael
Michael
2010年11月18日 GMT+1 11:29
yes meshing is an art ;) but are you really sure that the you will have a temperature gradient in the 5nm thickness direction, hence obliging you to use a 3D meshing and not surface physics ?
2010年11月18日 GMT+1 17:26
That's a good point. I will try to simulate it as a surface rather than a 3D object.
Thanks again.
Michael
Thanks again.
Michael
