meshing infinite element
I have 2 concentric spheres. The outer layer is an infinite element, I am trying to mesh it with swept layers and am getting an error message:"domain must be bounded by one connecting face only"
What am I doing wrong?
The automated meshing for infinite elements gives the same message
thanks for help
David
1 Reply Last Post 2016年5月10日 GMT+2 08:52
Posted: 9 years ago 2016年5月10日 GMT+2 08:52
It sounds like you may have created your IE layer by superimposing 2 spheres, and perhaps not using the correct Boolean operation to cut one from the other.
Have you tried using the "layer" option in the sphere command to create the IE layer? Simply specify the radial thickness of the layer you require.
Mark
It sounds like you may have created your IE layer by superimposing 2 spheres, and perhaps not using the correct Boolean operation to cut one from the other. Have you tried using the "layer" option in the sphere command to create the IE layer? Simply specify the radial thickness of the layer you require. Mark
