Half Sphere
I'm trying under COMSOL 4.0 to build a half sphere ... how can I manage ?
thanks
2 Replies Last Post 2010年11月24日 GMT+1 14:54
Posted: 1 decade ago 2010年11月24日 GMT+1 14:42
try out: make a full sphere, add a large block covering the half (boundary pasing through the sphere centre) and you can even in 4.1 use a workplane passing by the sphere centre to "box" the cut circle, and extrude at least to R the sphere radius.
Then use the difference bolean operation.
Its the same method as for 2D
Hi try out: make a full sphere, add a large block covering the half (boundary pasing through the sphere centre) and you can even in 4.1 use a workplane passing by the sphere centre to "box" the cut circle, and extrude at least to R the sphere radius. Then use the difference bolean operation. Its the same method as for 2D -- Good luck Ivar
Posted: 1 decade ago 2010年11月24日 GMT+1 14:54
thanks !
thanks !
