Easy way to flip the coordinate axis of my model.
Posted 2016年6月10日 GMT+2 21:00 Geometry, Parameters, Variables, & Functions Version 5.2 7 Replies
Actually I think a rotational transformation of my entire geometry will solve this problem.
This at least worked in the geometry workspace but the axis is still off in my plots, I guess I can just change views.
Have you tried to define a new "Definition View", then orient that one (either with the mouse or with the numerical values in the tab), then hit the Lock coordinates check button of the View node.
Later, by keeping this view the default (green rectangle in the icon in the model tree) you select in the graphical view icon the desired View and your screen image is oriented as desired (also the Zoom factor)
Exactly what I needed to do. Thank you!
Suggested Content
- BLOG Using General Extrusion Operators to Model Rotation
- KNOWLEDGE BASE Warning When Trying to Add a Local Database Stored on a Cloud Drive
- KNOWLEDGE BASE Graphical Glitches in the User Interface on Gaming Computers
- KNOWLEDGE BASE Failed to Connect to Apache Solr
- FORUM How to flip the x-axis?
