Temperature dependent heat capacity
Posted 2016年6月13日 GMT+2 10:45 Heat Transfer & Phase Change Version 5.0 2 Replies
Hi dear all,
I have a simple 2 layered heater structure: a phase change material X is in top of TiN. This X material has a time dependent resisitivity, thermal conductivity and heat capacity. At a temperature around 872 K all these parameters changes abruptly. Comsol shows good results when temperature is less than 872 K, but whenever it passes 872 K it runs for days with no results. To find why this happens I assigned constant numbers to 2 of them and applied only 1 temperature dependent parameter. For instance, heat capacity and thermal conductivity are assigned as constant with resisitivity changing with temperature. As a result, I found that due to heat capacity simulation lasts long. So is there any solution for this problem? Or how to solve it? Heat capacity is 202 till 874 K then it jumps to 14000 till 882 K and after this temperature-at 883 K it is 202.
2 Replies Last Post 2016年6月20日 GMT+2 17:06
