Is the LiveLink command mphint2 appropriate using the cut line dataset?
Posted 2016年7月11日 GMT+2 20:47 LiveLink for MATLAB 2 Replies
In Livelink application for MATLAB there is the command mphint2
using it to evaluate the results. In the evaluation of Derived Values I want to use the selection Cut Line 1 {cln1} instead of the Solution 1 {dset1} selection.
The command is
data = mphint2(model,<expr>,edim,'dataset',<dsettag>);
Can I use the selection Cut Line 1 {cln1} instead of the
Solution 1 {dset1}.
Or I must use an other command like mphglobal?
Thank you in advance
The command is
Solution 1 {dset1}.
2 Replies Last Post 2016年7月13日 GMT+2 01:44
