How to call the sound speed in material?
Hi all,
I would like to define the wavenumber (2*pi*freq / sound_speed) as a variable. I tried to call the sound speed as root.mod1.mat1.c, but it doesn't work. How can I call the value in the material library?
Thanks in advance for your help.
S.K.
3 Replies Last Post 2010年12月19日 GMT+1 20:23
Posted: 1 decade ago 2010年12月19日 GMT+1 10:00
if yi remeber right from the several treads passing on material naming (so far Ihave never had to use them myself) I seem to remember that there is a name segment more before the ".c"
root.mod1.mat1._a_name_is_missing_here.c
check the sucsection under which the sound of speed is labelled in the material section, its a hsortcut of the subsection identity
Or do a search on the forum for "mat1."
It's the week-end and I do not have COMSOL at home ;)
Hi if yi remeber right from the several treads passing on material naming (so far Ihave never had to use them myself) I seem to remember that there is a name segment more before the ".c" root.mod1.mat1._a_name_is_missing_here.c check the sucsection under which the sound of speed is labelled in the material section, its a hsortcut of the subsection identity Or do a search on the forum for "mat1." It's the week-end and I do not have COMSOL at home ;) -- Good luck Ivar
Posted: 1 decade ago 2010年12月19日 GMT+1 18:30
Thanks for your prompt response!!!
I set "root.mod1.mat1.def.c"; however, it does not work.
S.K.
Thanks for your prompt response!!! I set "root.mod1.mat1.def.c"; however, it does not work. Best regards, S.K.
Posted: 1 decade ago 2010年12月19日 GMT+1 20:23
you are accessing an internal naming there so it might be mat2 or mat3 if you have several materials or if you have defined a few materials, and then deleted some. Check the dentifiers and "tags" names, and then check in the equations or try to find a place where you variable is called and look at the convention used by COMSOL in the "equation sub-tab.
Unfortunately I do not have access to my COMSOL from home ;)
Hi you are accessing an internal naming there so it might be mat2 or mat3 if you have several materials or if you have defined a few materials, and then deleted some. Check the dentifiers and "tags" names, and then check in the equations or try to find a place where you variable is called and look at the convention used by COMSOL in the "equation sub-tab. Unfortunately I do not have access to my COMSOL from home ;) -- Good luck Ivar
