stirred tank reactor
I am trying to model a bio-reactor in COMSOL, in the reactor how can I model the breakage and coalescence of air bubbles. Which physics should I use which takes this into consideration?
Kindly help me out with this.
Ravi
1 Reply Last Post 2016年11月8日 GMT+1 15:41
Hello Ravi Kumar Garikina
Posted: 9 years ago 2016年11月8日 GMT+1 15:41
Hi Ravi
First, you have to use a rotational machinery physics, tanks are agitated and you can work in 3D. I recommend you use swept meshes. Then you calculate the flow. Using that solution, I've never tried it but, you can use a Euler-Euler mixture physics, and I suppose you can use a MATLAB code to model coalescence and breakage, this is difficult. You can find papers on the internet that model coalescence and breakage.
Good luck.
Hi Ravi First, you have to use a rotational machinery physics, tanks are agitated and you can work in 3D. I recommend you use swept meshes. Then you calculate the flow. Using that solution, I've never tried it but, you can use a Euler-Euler mixture physics, and I suppose you can use a MATLAB code to model coalescence and breakage, this is difficult. You can find papers on the internet that model coalescence and breakage. Good luck.
