density variation in rotating fluid
Is it possible to model density variation in a rotating fluid?
3 Replies Last Post 2010年12月27日 GMT+1 18:16
Posted: 1 decade ago 2010年12月27日 GMT+1 11:47
that depeds what you mean by "density" variations. If it's simply to add a centrifugal body load then yes this is rather straight-forward you add a force in a cylindrical reference as
Fr=rho*w^2*R
there is an example in structural doc for a rotating shaft
Hi that depeds what you mean by "density" variations. If it's simply to add a centrifugal body load then yes this is rather straight-forward you add a force in a cylindrical reference as Fr=rho*w^2*R there is an example in structural doc for a rotating shaft -- Good luck Ivar
Posted: 1 decade ago 2010年12月27日 GMT+1 14:27
Thanks Ivar,
I could not find the example you referred. Can you please give me more information about that. Moreover how (in which node) I can add the centrifugal body load. If I am using rotating machinery, should I express this under 'volume forces'.
Thanks Ivar, I could not find the example you referred. Can you please give me more information about that. Moreover how (in which node) I can add the centrifugal body load. If I am using rotating machinery, should I express this under 'volume forces'.
Posted: 1 decade ago 2010年12月27日 GMT+1 18:16
Volume for ce or body force are forces acting on each element of a domain therefore the
F[N/m^3] = solid.rho[kg/m^3]*(w[1/s])^2*r[m]
where w is the rotation speed
Hi Volume for ce or body force are forces acting on each element of a domain therefore the F[N/m^3] = solid.rho[kg/m^3]*(w[1/s])^2*r[m] where w is the rotation speed -- Good luck Ivar
