Adaptive mesh refinemend during parametric sweep
I want to run a parametric sweep with a model, where I first solve for u v p with the swept variable being the inlet volumetric flow rate, then solve for c, where I use adaptive mesh refinement.
The problem is, that after the first parameter, the strongly refined mesh is used in the next parameter calculation and not the initial mesh.
How can I tell comsol from the GUI to start with equal meshes (the intial low resolution mesh) for each parameter but do mesh refinement steps during solving.
Regards
Matthias
4 Replies Last Post 2011年3月24日 GMT+1 08:10
Posted: 1 decade ago 2011年1月11日 GMT+1 17:51
in 3.5 (comapred to v4) you have less control on your meshing, I'm not sure how to "restart" the meshing for the parametric sweep anylonger in 3.5a, passing via matlab is certainly possible
Hi in 3.5 (comapred to v4) you have less control on your meshing, I'm not sure how to "restart" the meshing for the parametric sweep anylonger in 3.5a, passing via matlab is certainly possible -- Good luck Ivar
Posted: 1 decade ago 2011年1月11日 GMT+1 21:16
Hi Ivar,
thanks for your response.
I managed to get a solution by using Matlab and a loop, where the swept parameter is changed by multiplication with the loop counter "i" and the mesh is reset at each loop run.
Still, I have a question concerning the call of parameters which could be used as a list, e.g. in a text file.
Is it possible to read single defined values from such a textfile and use them in a loop in the comsol m-file, e.g. entry at line "i" in the text file according to the "i" given in the loop counter with "for i = 1:x"?
The intention is to use arbitrary sets of values, which can not be expressed by a function or series.
I only know from the manual how to call functions from text files with "fem.functions{2}.fileindex = {i,...};" but can this be applied in my case?
I feel, there should be an elegant solution to this, which I might not be able so see.
(have to try this out though)
Regards
Matthias
Hi Ivar, thanks for your response. I managed to get a solution by using Matlab and a loop, where the swept parameter is changed by multiplication with the loop counter "i" and the mesh is reset at each loop run. Still, I have a question concerning the call of parameters which could be used as a list, e.g. in a text file. Is it possible to read single defined values from such a textfile and use them in a loop in the comsol m-file, e.g. entry at line "i" in the text file according to the "i" given in the loop counter with "for i = 1:x"? The intention is to use arbitrary sets of values, which can not be expressed by a function or series. I only know from the manual how to call functions from text files with "fem.functions{2}.fileindex = {i,...};" but can this be applied in my case? I feel, there should be an elegant solution to this, which I might not be able so see. (have to try this out though) Regards Matthias
Posted: 1 decade ago 2011年3月23日 GMT+1 20:04
Would you happen to now how to "restart" the meshing in between parameter steps in version 4.1?
John
[QUOTE] Hi in 3.5 (comapred to v4) you have less control on your meshing, I'm not sure how to "restart" the meshing for the parametric sweep anylonger in 3.5a, passing via matlab is certainly possible -- Good luck Ivar [/QUOTE] Would you happen to now how to "restart" the meshing in between parameter steps in version 4.1? Thanks, John
Posted: 1 decade ago 2011年3月24日 GMT+1 08:10
normally with a "true "Parametric Sweep, if you change the geometry, it will remesh at each step (V4.1)
Hi normally with a "true "Parametric Sweep, if you change the geometry, it will remesh at each step (V4.1) -- Good luck Ivar
