view cross section mesh
Alex Moreno Bellostes
I need to see the mesh of an inner element of a cylinder, then I want to make cut in longitudinal section, how can I do it.
Thank you
3 Replies Last Post 2017年1月18日 GMT+1 17:53
Posted: 9 years ago 2017年1月18日 GMT+1 17:08
Hello Alex,
You do that by adding a Filter to your Mesh plot, see e.g. www.comsol.com/community/forums/general/thread/121691
Hello Alex, You do that by adding a Filter to your Mesh plot, see e.g. https://www.comsol.com/community/forums/general/thread/121691 Best, Jeff
Posted: 9 years ago 2017年1月18日 GMT+1 17:23
Hi, thanks for all,
i had problems because the units of bolean are meters and i'mworking with milimeters
Hi, thanks for all, i had problems because the units of bolean are meters and i'mworking with milimeters
Posted: 9 years ago 2017年1月18日 GMT+1 17:53
OK. I presume you've figured by now that you can use square brackets to denote units, so you can use something like
y<20[mm]
as a filter if you don't want to do the conversion "manually" to y<.02.
OK. I presume you've figured by now that you can use square brackets to denote units, so you can use something like y
