mpheval command
Dear all,
I have got some questions regarding the mpheval command, which are not very clear in the documentation.
There is a model file, that I export to matlab, that contains 2 studies, with a parametric sweep and a transient solver in each of the two studies.
The mpheval command does not like the parameter 'dataset', solution [number whatever].
It won't find any of the solution datasets, that are defined in the Model file itself.
There is one solution data set for the first study and one for the second.
My most important issue is: how can I address the results of the two different studies of the model file?
An other question is the 'solnum' parameter. With this I can obviously define the time step number.
E.g. 'solnum', 10 would give the data of the 10th time step.
So why is there also a parameter 't' in the mpheval? And what happens, if I use both in one call of mpheval with contradicting values.
E.g. 'solnum', 10 (the 10th time step, eg. t=1000) and 't', 2000 in one call?
Will it then return data from t=1000 or t=2000?
At least it does not give an error message, which is strange to me.
Thanks a lot for any answers,
Juergen
5 Replies Last Post 2015年8月6日 GMT+2 22:39
Posted: 1 decade ago 2011年1月27日 GMT+1 17:17
For the first issue I just found a solution finally.
MPHEVAL expects not the "visible" name of the solution dataset, which you can see in the comsol model, e.g. "Solution 1", etc.
You have to right click the "Solution 1" in the model tree and click on properties.
There you can see the "Tag" propertie, which is e.g. "dset1".
This is, what MPHEVAL needs.
'dataset', 'dset1' will be accepted, whereas 'dataset', 'solution 1' will fail.
For the first issue I just found a solution finally. MPHEVAL expects not the "visible" name of the solution dataset, which you can see in the comsol model, e.g. "Solution 1", etc. You have to right click the "Solution 1" in the model tree and click on properties. There you can see the "Tag" propertie, which is e.g. "dset1". This is, what MPHEVAL needs. 'dataset', 'dset1' will be accepted, whereas 'dataset', 'solution 1' will fail.
Posted: 1 decade ago 2011年2月17日 GMT+1 22:00
Hello Jürgen,
sounds german, I am also a german kraut :)
Your issue sounds similar to mine, and I just found a solution to it.
It really does depend, what you want to evaluate.
mpheval is a strange command. At first I also thought I have to use it for evaluating an physical expression (eg magnetic flux density) on a specified point in my model... wrong.
mpheval evaluates expression on all node points. Therefore you get very much postdata with coordiates of the node points and much more you do not want to know.
If you want to evaluate a Variable or global expression defined in your model you need to use mphglobal command, which is not that complicated.
Example:
F_Matlab_var = mphglobal(model,'F_comsol_var'); % Evaluation of a variable defined in your comosl model
If you want to do a real pointevaluation, as your are used to do in comsol, you need to use the mphinterp
command!!!
Example:
point_coord = [40-0.625,-27]' % coordinates of point to evaluate -Attention ' (transposition) --> coords. in column
P_normB = mphinterp(model,'mf.normB','coord',point_coord) % evaluation of normal Flux density at coords
User guide sometimes i a little cryptic to me but finally it helped. interp just made me think of interpolation, so I didn't gave attention to it. Took me almost a week to find out and unfortunatelly nobody could help in the Forum. I am still even waiting for a comsol support answer.
Hope I could help
Sincerely
Oliver
Hello Jürgen, sounds german, I am also a german kraut :) Your issue sounds similar to mine, and I just found a solution to it. It really does depend, what you want to evaluate. mpheval is a strange command. At first I also thought I have to use it for evaluating an physical expression (eg magnetic flux density) on a specified point in my model... wrong. mpheval evaluates expression on all node points. Therefore you get very much postdata with coordiates of the node points and much more you do not want to know. If you want to evaluate a Variable or global expression defined in your model you need to use mphglobal command, which is not that complicated. Example: F_Matlab_var = mphglobal(model,'F_comsol_var'); % Evaluation of a variable defined in your comosl model If you want to do a real pointevaluation, as your are used to do in comsol, you need to use the mphinterp command!!! Example: point_coord = [40-0.625,-27]' % coordinates of point to evaluate -Attention ' (transposition) --> coords. in column P_normB = mphinterp(model,'mf.normB','coord',point_coord) % evaluation of normal Flux density at coords User guide sometimes i a little cryptic to me but finally it helped. interp just made me think of interpolation, so I didn't gave attention to it. Took me almost a week to find out and unfortunatelly nobody could help in the Forum. I am still even waiting for a comsol support answer. Hope I could help Sincerely Oliver
Posted: 1 decade ago 2011年2月21日 GMT+1 08:46
Hi Oliver,
thanks for your reply.
I will try the things you suggested!
It sounds promising, maybe it is less memory consuming than mpheval.
Juergen
Hi Oliver, thanks for your reply. I will try the things you suggested! It sounds promising, maybe it is less memory consuming than mpheval. Best regards, Juergen
Posted: 1 decade ago 2013年12月10日 GMT+1 23:39
I was trying to figure out how to deal with this myself...
Incase someone finds this thread before they find what they're looking for in the LiveLink Help Manual. I'm going to suggest you look at the help manual, for the command: mphsolutioninfo
Also instead of navigating the trees that this command creates, it may be simpler to just export the data.
The trees that can be read with mphsolutioninfo will most likely provide you with the proper tags necessary.
I was trying to figure out how to deal with this myself... Incase someone finds this thread before they find what they're looking for in the LiveLink Help Manual. I'm going to suggest you look at the help manual, for the command: mphsolutioninfo Also instead of navigating the trees that this command creates, it may be simpler to just export the data. The trees that can be read with mphsolutioninfo will most likely provide you with the proper tags necessary.
Posted: 1 decade ago 2015年8月6日 GMT+2 22:39
Hi everyone,
taking into account you are talking about "mpheval" function, I would like to know if someone know how to set the number of decimals of the output data.
Thanks in advance
Catalina
Hi everyone, taking into account you are talking about "mpheval" function, I would like to know if someone know how to set the number of decimals of the output data. Thanks in advance Catalina
