Internal error in boundary respecting
Posted 2009年10月28日 GMT+1 16:38 Mesh Version 4.3a 8 Replies
the fuel is passed from the closed side.
The problem is while i am going to mesh it itz showing " error : Internal error in boundary respecting in subdomain 1 " plz guide me what is this error asap.
i am using comsol 3.4 version.
from my experience, such erros arrive when I have poorly defined my geometry, or imported it from programs that are not clean in the way they close the poly-lines defining superiour geometries, this often happens for dxf file format. I would recheck my geometry, and use the "repare" and or "defeaturing search", I suppose its already there in V3.4
I'm working on a geometry and I got such an error right now.
I did repair as you said, but it did not work. It gave me such an error:
"Failed to respect boundary element edge on geometry face."
one boundary couldn't be meshed with the remaining geometry.
Why that can be happening?
thanks
physics undergrad
loves photon.
probably you have very small/short lines, or small sharp faces that implies very small mesh elements, or the repair did not work properly
how I created the geometry:
after creating two cylinders and one sphere, I intersected one cylinder one sphere with keeping input objects, so I created middle domains that are created by the intersection. Then I used delete entities to delete the remaining parts of the cylinder.
The result is one sphere with two caps at opposite ends.
physics undergrad
loves photon.
my experience is that you should then identify where the mesh issue is and adapt the mesh manually to start to make some local entities with a finer mesh and leave the global "normal" mesh to avoid that you increase the mesh density everywhere.
But mesh density is your discretisation, so once you have solved, you shoul always check the gradients of your solutions, do you have several elements across anny steep gradient ? if not here you shoul densify locally your mesh
I am trying to mesh the geometry as shown in the attachment. It has a thickness of about 0.05inches.
I tried to mesh using most of the mesh options available in 4.3a version, but still the error persists.
May I please know how to work on the problem?
I would have used a free triangular mesh on the arc then swept through the rest of the domain with a distribution and finally used a converted to change the squares created by the swept mesh into triangles.
Andy
