How do I access solutions at specific coordinates
Hi all
It's a naive question, but how can I access solutions to variables at specific coordinates. For example i want to plot variable1(x=0.2,y=0.5) vs time. Thanks!
3 Replies Last Post 2011年8月26日 GMT+2 01:28
Posted: 1 decade ago 2011年2月4日 GMT+1 23:31
To rephrase my question. I have the solution to a certain variable, var1 vs. radial distance at many time points. I want to plot radial distance vs. time for a particular value of var1. How can i do this?
Posted: 1 decade ago 2011年2月5日 GMT+1 09:00
in v3.5 via matlab you used the postinterp() operator, but now it has changed name in V4, see the doc.
I mostly make a point or better an internal edge/surface alon the path I want to retrieve and then I plot out the values thereon in a table. You have also the solution edge/surface ... section
Hi in v3.5 via matlab you used the postinterp() operator, but now it has changed name in V4, see the doc. I mostly make a point or better an internal edge/surface alon the path I want to retrieve and then I plot out the values thereon in a table. You have also the solution edge/surface ... section -- Good luck Ivar
Posted: 1 decade ago 2011年8月26日 GMT+2 01:28
See which doc?
Link to it?
Can't you just tell me the name of the new operator?
See which doc? Link to it? Can't you just tell me the name of the new operator?
