Laminar Flow
I'm simulating a micro channel using Laminar flow Physics. My model works perfectly when i give flow rate at the input and chose "0" Pa at the output. The solution doesn't converge when i chose flow rate at the output as well. I'm new to the fluid flow simulations and i'm not sure if i was able to make my self clear.
Regards
Adil
1 Reply Last Post 2017年4月1日 GMT+2 18:25
Posted: 8 years ago 2017年4月1日 GMT+2 18:25
Regards
Adil
Adil,
I'm not sure about my answers. However, there are two issues with your new boundary condition:
1) When you impose a flow rate at a boundary, Comsol applies a uniform velocity at that boundary, which physically does not happen at the channel's outlet.
2) Imposing a uniform velocity distribution at both ends means that there is no pressure difference between the inlet and outlet. So Comsol can not find a solution for this pressure-driven flow.
Amin,
[QUOTE] Hi, I'm simulating a micro channel using Laminar flow Physics. My model works perfectly when i give flow rate at the input and chose "0" Pa at the output. The solution doesn't converge when i chose flow rate at the output as well. I'm new to the fluid flow simulations and i'm not sure if i was able to make my self clear. Regards Adil [/QUOTE] Adil, I'm not sure about my answers. However, there are two issues with your new boundary condition: 1) When you impose a flow rate at a boundary, Comsol applies a uniform velocity at that boundary, which physically does not happen at the channel's outlet. 2) Imposing a uniform velocity distribution at both ends means that there is no pressure difference between the inlet and outlet. So Comsol can not find a solution for this pressure-driven flow. Amin,
