How to set Acoustic Source
Hi!
I have a question on the Acoustics module in Comsol, regarding how to set a monopole acoustic source.
I have a point acoustic source characterized by a modulated sin wave:
In Matlab coding,
y=-sin(2.*pi.*Freq.*Ts).*hanning(length(Ts))'
Here, the acoustic source is described in terms of particle displacement, y.
However, I understand that in Comsol, to set a point source, we are supposed to go to Physics > Point settings > Pressure acoustics, and select the type of source as flow, intensity and power.
My question is, how do we convert the description of the point source from displacement to a description in terms of either flow, intensity or power?
Thanks!
8 Replies Last Post 2014年7月31日 GMT+2 09:13
Posted: 2 decades ago 2009年11月9日 GMT+1 22:48
Hi I have same problem. Did you find any solution for that? Please let me know.
Aram
Hi I have same problem. Did you find any solution for that? Please let me know. Thanks Aram
Posted: 1 decade ago 2010年10月14日 GMT+2 08:13
I have the same problem as you had faced. Will you please tell me, how did you solve it ?
Thanks in advance,
Kiran
Hi, I have the same problem as you had faced. Will you please tell me, how did you solve it ? Thanks in advance, Kiran
Posted: 1 decade ago 2011年1月27日 GMT+1 00:06
Hi!
In Matlab coding,
Thanks!
Hi.
Have you figured out how to do yet? Thanks~
[QUOTE] Hi! I have a question on the Acoustics module in Comsol, regarding how to set a monopole acoustic source. I have a point acoustic source characterized by a modulated sin wave: In Matlab coding, y=-sin(2.*pi.*Freq.*Ts).*hanning(length(Ts))' Here, the acoustic source is described in terms of particle displacement, y. However, I understand that in Comsol, to set a point source, we are supposed to go to Physics > Point settings > Pressure acoustics, and select the type of source as flow, intensity and power. My question is, how do we convert the description of the point source from displacement to a description in terms of either flow, intensity or power? Thanks! [/QUOTE] Hi. Have you figured out how to do yet? Thanks~
Posted: 1 decade ago 2011年6月5日 GMT+2 04:54
i have the similar question for setting the dipole source
Posted: 1 decade ago 2011年9月8日 GMT+2 23:24
Have you figured out the problem yet?
Hi, Have you figured out the problem yet? Thanks
Mads Herring Jensen COMSOL Employee
Posted: 1 decade ago 2011年9月13日 GMT+2 10:54
Hi all
When entering a flow point source in the frequency domain, the source amplitude S has the dimension m^3/s. In order to set the "radial displacement" U0 of the source you can enter S = U0*acpr.iomega*4*pi.
Best regards
Mads
Hi all When entering a flow point source in the frequency domain, the source amplitude S has the dimension m^3/s. In order to set the "radial displacement" U0 of the source you can enter S = U0*acpr.iomega*4*pi. Best regards Mads
Posted: 1 decade ago 2012年2月4日 GMT+1 10:09
I too have a problem in something related to the above discussion. If anyone can explain how COMSOL solves the point source problems. The documentation doesn't explain much..
Posted: 1 decade ago 2014年7月31日 GMT+2 09:13
Then how I can set Q in the monopole source whose dimension is 1/s^2 in 2D.
