2011年3月2日 GMT+1 13:34
In v4.1 partly I believe, you can have several meshes (even for the same domains) and then for each solver node you might define the mesh and the specific physics to which it applies to (not necessarily all physics for each solver).
then remains how to couple them by a segregated technique further down in the solver tree. Haven't tried myself , but manually you can do many things
2011年3月2日 GMT+1 13:40
Interesting!
Maybe you can double the geometry and transfer the needed value from one geomtry/physics to another one using extrusion variables.
I attached a file where I used the temperature of subdomain 1to calculate the density of subdomain 2.
Could be a starting point for you?!?
regards
Interesting!
regards
2011年3月2日 GMT+1 13:47
Thanks for your comments and suggestions. That sounds promising.
Unfortunately, I have no HT license, so I cannot open your attached file.
Best regards
Best regards
2011年3月2日 GMT+1 13:51
Your model is to be opened in v3.5a since the v4.1 COMSOL get lost in the translation of point selections for the extrusion coupling variables
Indeed another way to do things
By the way multigrid solving isn't that also about multiple mesh ?
I must admit that I play with the physics, and leave mostly COMSOL choose the math solvers by default, mostly it works fine ;)
2011年3月2日 GMT+1 14:02
Ohh sorry.
I transfered it to the "normal" heat transfer mode. And yes, it's 3.5a.
If you can open this model, chek the varaibles T, myT and k_ht. And the extrusion variables for subdomains.
Ohh sorry.
2011年3月2日 GMT+1 14:43
Very interesting!!
Thanks you
Very interesting!!
Thanks you
