Cooling chamber
Posted 2011年3月10日 GMT+1 14:24 Version 3.5a, Version 4.2a 2 Replies
I am doing a work placement at Roctool, a french company working on induction heating of industrial molds for thermoplastic injection.
I am currently using the COMSOL 3.5a version to simulate the joule effect induced by a current wandering through a copper wire.
I am running a 2D simulation, using the "conduction-transient analysis" (heat transfer) and "perpendicular induction currents-time harmonic analysis"(quasi-statics,magnetic).
By applying an external current density and setting the resistive heating (Qav_emqa*(t<X)) as a heat source in the conduction subdomain settings, the simulation is working just fine.
The results would be quite realistic if it wasn't for the cooling system. For the moment, I've only been able to apply a constant heat transfer coefficient (around 10000 W/(m^2.K), which is an approximation of the heat transfer coefficient of water for turbulent flow) on the boundary of the cooling channel.
I do obtain results, but in order to improve them I wish to switch to a cooling chamber model, located behind the heating system. The idea is to absorb the heat provided by induction using a change of phase of the working fluid (using the latent heat to have a much more efficient cooling).
I'm still quite new to Comsol, therefore I would like to now if you happen to have preexisting research on this case or if similar models that are available (I've been searching on the website, without success). The problem is the company doesn't have all the application modes, only Comsol multiphysics, ac/dc module, heat transfer module and structural mechanics module. On the few similar cases i've found, it seems the chemical engineering module is quite useful to caracterize the change of phase, and input a latent heat value. Is it possible to do without?
So far the simulation hasn't been too complex, but I would like to add a velocity field for the fluid, linked with its change of density and dynamic viscosity. I intend to keep the ambient pressure of the cooling chamber constant, since the liquid phase and vapor phase remain at an equilibrium by using a heat exchanger. My internship supervisor has told me that the point isn't to start from scratch, but rather to find preexisting similar subjects and simulations to help.
If anyone of experience would be ever so kind as to provide information on how to handle the problem, I would be very grateful.
It seems the moderator mr.Kjelberg, has answers to everything ;)
2 Replies Last Post 2012年1月9日 GMT+1 13:58
