COMSOL Employee
8 years ago
2017年8月18日 GMT+2 21:33
Hello Asha,
See https://www.comsol.com/blogs/manually-work-entity-numbers-selections/
8 years ago
2017年8月18日 GMT+2 22:24
Hello Jeff,
Thank you for valuable suggestion.
But in my geometry, i am having 200 circles and can't let the material property to get changed within each domain. So i used 'for' loop while using 'ballselection' for 200circles as below:
numpart=200
for j=1:numpart
selball=(j);
ballsel1=strcat('c',selball)
partno=j;
ctxname=(ctx(partno));
ctyname=(cty(partno));
model.geom('geom1').create(ballsel1, 'BallSelection');
model.geom('geom1').feature(ballsel1).set('r', [radpart]);
model.geom('geom1').feature(ballsel1).set('posx', [ctxname]);
model.geom('geom1').feature(ballsel1).set('posy', [ctyname]);
model.geom('geom1').feature(ballsel1).set('condition', 'allvertices');
end
model.geom('geom1').run;
But its producing following error:
Error using PermittThreeCirc (line 46)
Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: An object with the given name
already exists
(rethrown as com.comsol.util.exceptions.FlException)
An object with the given name already exists
An object with the given name already exists.
- Tag: ballsel1
Please suggest solution.
Hello Jeff,
numpart=200
for j=1:numpart
selball=(j);
partno=j;
end
Exception:
already exists
- Tag: ballsel1
Lars Gregersen
COMSOL Employee
8 years ago
2017年8月22日 GMT+2 12:54
I can't see why your code should result in the error message you see. Can you send your model and script to support?
What type of variation of material parameters do you wish to have for each circle? Are all the parameters different or can you group the material settings?
You can either use different materials for different selections or you can define Variables (Component->Definitions->Variables) that use different expressions in different domains.
I would use the function mphselectcoords for finding the entity numbers. It works similarly to a BallSelection, but doesn't add selections to the model. You can then use the returned entity numbers when setting up your model.
Lars Gregersen
Comsol Denmark
Lars Gregersen
Comsol Denmark
8 years ago
2017年8月22日 GMT+2 13:04
Hello Lars,
Thank you for your valuable suggestion.
This link
www.comsol.com/blogs/manually-...ork-entity-numbers-selections/ worked for me.
Actually i was writing code like
Instead of
tag=model.geom('geom1').feature.uniquetag('ballsel');
model.geom('geom1').feature.create(tag, 'BallSelection');
Asha Sharma
Hello Lars,
This link www.comsol.com/blogs/manually-...ork-entity-numbers-selections/ worked for me.
Instead of
Asha Sharma
