Draw Cut Line
Posted 2017年8月22日 GMT+2 11:04 Low-Frequency Electromagnetics, Results & Visualization Version 5.3 2 Replies
Good morning,
I use Cut Lines on a specified plane within the "Data Set" section, in order to establish a measurement path for post-processing.
The goal is to compute the electric field on a specified zone.
I have two questions :
- to verify the position of the cut line (after having inserted the parameters for the start/end of the line...) I usually plot it on the geometry. This operation ("draw a line") requires several minutes to be completed. Why is this the case ? I have a powerful Workstation, so it is not a problem of computational power.
- Is there a way to define the resolution of the "Cut Line" ? How many point/unit of length are computed ?
- Is there a way to define different shapes within the dataset section (arc ?) In some occasions, you want to know the electric field along a curved line (which might not have a "simple" definition for its analytic expression...)
Daniele
Daniele
2 Replies Last Post 2017年8月23日 GMT+2 13:49
