Fluid flow boundary integration
for 2-D axis, in order to find the volumetric flow rate, just perform integration across the boundary will generate [m^3/s]
I am now doing with 2-D, integration across the boundary will only generate [m^2/s]. Is there any method to find volumetric flow rate[m^3/s] in 2-D?
Thanks.
5 Replies Last Post 2011年3月15日 GMT+1 16:18
Posted: 1 decade ago 2011年3月14日 GMT+1 13:17
in 2D and 2D axi the integration over an edge is in 2D assumed over an area of by default 1[m] depth (slightly physics dependent, always check the main physics node for default depth ("d" or "thickness" values)
in 2D-axi you must multiply by 2*pi*r the "loop length" tis can be done ba COMSOL in Results post processing mode if you go to the advanced tab ana select integrate over volumes for 2D-axi. But you must specify it manually if you use "operator" or integration coupling variables
Hi in 2D and 2D axi the integration over an edge is in 2D assumed over an area of by default 1[m] depth (slightly physics dependent, always check the main physics node for default depth ("d" or "thickness" values) in 2D-axi you must multiply by 2*pi*r the "loop length" tis can be done ba COMSOL in Results post processing mode if you go to the advanced tab ana select integrate over volumes for 2D-axi. But you must specify it manually if you use "operator" or integration coupling variables -- Good luck Ivar
Posted: 1 decade ago 2011年3月14日 GMT+1 15:13
Thanks Ivar for advice, for 2-D axis, similar integration can be found at tutorial-peristaltic pump. Quite nice the simulation.
However, for my case, I am applying 2-D where integration over the boundary will only create area flow rate [m^2/s].
Is there any possible we can have volume flow rate [m^3/s]?
Thanks and appreciate for advice.
Thanks Ivar for advice, for 2-D axis, similar integration can be found at tutorial-peristaltic pump. Quite nice the simulation. However, for my case, I am applying 2-D where integration over the boundary will only create area flow rate [m^2/s]. Is there any possible we can have volume flow rate [m^3/s]? Thanks and appreciate for advice.
Posted: 1 decade ago 2011年3月15日 GMT+1 09:21
I believe its so if you multiply by the depth "z" direction, as an edge in 2D is a surface of a given depth (mostly by default 1[m]
Hi I believe its so if you multiply by the depth "z" direction, as an edge in 2D is a surface of a given depth (mostly by default 1[m] -- Good luck Ivar
Posted: 1 decade ago 2011年3月15日 GMT+1 14:55
Hi Ivar,
I am trying with the Results post processing boundary integration mode but it only shows area flow rate when I select the inlet boundary. and surface integral is only applied to axisymmetric mode. Thus, I think the flow rate only applied to area flow rate in 2-D mode.
Hi Ivar, I am trying with the Results post processing boundary integration mode but it only shows area flow rate when I select the inlet boundary. and surface integral is only applied to axisymmetric mode. Thus, I think the flow rate only applied to area flow rate in 2-D mode.
Posted: 1 decade ago 2011年3月15日 GMT+1 16:18
I'm somewhat confused now, it's difficult to understand correctly only with words.
Have you tried to make a simple example, that you can easily check by a simple analytical formula, then you ususlly arrive to better understand the relationship required, or missing
Hi I'm somewhat confused now, it's difficult to understand correctly only with words. Have you tried to make a simple example, that you can easily check by a simple analytical formula, then you ususlly arrive to better understand the relationship required, or missing -- Good luck Ivar
