2011年3月15日 GMT+1 16:32
Search for "state space" or "mphstate()"
By the way the doc is slightly misleading, here is a code that works for the doc (I received it from Remi of COMSOL support)
% Load the heat_convection_2d.mph model
model = mphload('heat_convection_2d.mph');
% Set the temperature condition with a constant parameter
model.param.set('T0','373');
model.physics('ht').feature('temp1').set('T0', 1, 'T0');
% Add a point probe at [0.3;0.8]
pdom1 = model.probe.create('pdom1', 'DomainPoint');
pdom1.model('mod1'); pdom1.setIndex('coords2','0.8',0,0);
pdom1.setIndex('coords2','0.3',0,0);
% Extract matrix data
M = mphstate(model,'sol1','out',{'MA' 'MB' 'C' 'D'},...
'input','T0', 'output', 'mod1.ppb1');
At least this works OK for 4.1 ;)
2011年4月1日 GMT+2 18:19
Hi Ivar,
Did you verify that the solution you get from using the state space matrices is the same as the solution you get from the COMSOL GUI?
V/R,
Andrew Wang
Hi Ivar,
V/R,
Andrew Wang
2011年5月3日 GMT+2 17:02
Hi Andrew
I have not worked on it since last week -- I will hopefully get it done within a couple of days and then will let you know.
However, for the simple 2D heat-transfer problem (non-coupled, single physics problem), I believe it should give more or less the same results. But I will update once I have implemented it.
Madu
Hi Andrew
Madu
2011年5月6日 GMT+2 22:40
I worked this example in MATLAB (LiveLink), literally cutting and pasting from Ivar's example. MATLAB throws no errors, but the 'C' matrix is empty which is something I would not expect considering the probe. Also, I slightly modified the example by asking for the 'A' and 'B' matrices vice the 'MA' and 'MC' matrices. In these cases, I get the following error:
??? Java exception occurred:
Exception:
com.comsol.util.exceptions.FlException: Unknown property
Unknown property
- Property: A
Does someone on this Forum know if there are some bugs in the code? If so, has anyone heard when a fix is due out?
Thanks to all who take the time to answer this forum! You are doing a great service to us 'new-to-COMSOL' folks.
Exception:
Unknown property
- Property: A
2011年5月7日 GMT+2 12:48
I have not fully amnaged to get it eitherworkin under v4.1, so I'm waiting for 4.2. But there was another thread the last days, I believe using JAVA describing how to (or what is Matlab ?, I'm looking at to many threads here ;)
oups it was the next thread in the list, here is the link
www.comsol.eu/community/forums/general/thread/13667/#p49298
http://www.comsol.eu/community/forums/general/thread/13667/#p49298
